Discussion topic: Sky Q - No Internet Connection with Virgin Media Broadband
Message posted on
28 Mar 2023
01:32 PM
- last edited:
28 Mar 2023
02:21 PM
by
Chloe-W22
Today noticed I could not download anything to my Sky Q box - using virgin broadband. All my other devices in the house are working fine. No issue with my Broadband.
Tried restarting router
restarting Sky Q Box
Doing a network reset on Sky Q
nothing works. It was all working last night - but today seems dead. Have tried everything. Anyone got any ideas on this ? thanks
Message posted on 28 Mar 2023 02:16 PM
Re: Sky Q Finds wiFi but no connection today
Hey @dino9898,
Are you on VM Broadband by any chance? Virgin Media are investigating an issue with Sky Products connecting to the internet today, the main chain is on the Glass board 🙂
Message posted on 28 Mar 2023 02:18 PM
Hi yes I am with Virgin Broadand using Sky Q box (not glass) thanks will check the other board you shared
Message posted on 28 Mar 2023 02:20 PM
No probs, it's getting looked at as we speak.
PS - I'm going to amend your title slightly so other Sky Q customers can find it if they are experiencing the same 🙂
Message posted on 28 Mar 2023 02:21 PM
Cheers Chloe - to clarify this virgin router/hub issue is affecting both SKY Q and Sky Glass customers ?
thank you )
Message posted on 28 Mar 2023 02:23 PM
It is unfortunately, Q, Glass and Stream
Message posted on 28 Mar 2023 02:24 PM
well at least its not local to my equipment so will just wait this out for Virgin & sky to find the fix
thank you for clarifying this )
Message posted on 28 Mar 2023 03:12 PM
Re: Sky Q - No Internet Connection with Virgin Media Broadband
All back up and running again for those who aint seen the other thread - and others saying its all working again - happy days )
Message posted on 22 Apr 2023 09:39 PM
Sky Q wont connect to Virgin Broadband wirelessly
Hi all,
This may have been answered a thousand times, but I'm not too techicial and am slightly lost on some of the answers that appear similar.
My Sky Q box just wont connect to my Virgin Media WiFi.
Absolutely nothing wrong with my WiFi. Works for PS5, Alexa, tablet etc. It's fine.
I key in the Network details on Sky Q. Seems to connect for a second then just disconnects and tell me I dont have internet connection.
Any advice would be greatly appreciated as this has been going on for a year and I'm actually fed up with Sky Q.
Message posted on 22 Apr 2023 09:40 PM
Re: Sky Q wont connect to Virgin Broadband wirelessly
Should have mentioned....I'm in Ireland
Message posted on 22 Apr 2023 10:28 PM
Very odd I personally have sky stream and it was more than happy to connect to my virgin brodband when I had it. Although when we where transitioning from virgin to bt and sky our virgin 360 tv box point blank refused to connect wirelessly to my bt hub but would accept internet via Ethernet from the same hub. I'd attempt to connect via Ethernet cable if that works maybe inveset in a powerline adapter or else contact virgin/sky
BT 500 + whole home disc
Message posted on 23 Apr 2023 07:45 PM
Are you using the wps button on the hub & on the Sky Q box to connect or manually entering the SSID & password?
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 23 Apr 2023 08:28 PM
Hi Twilight+Princess,
I choose add broadband provider, Virgin, find the relevant broadband name, enter the password. Occasionally it says connected. For a couple of seconds. Then i get the 'x' saying Sky Q not connected to broadband
Message posted on 24 Apr 2023 01:16 PM
I would try wps via the buttons. I have a Hub 3 with Virginmedia & setup was easy that way.
Message posted on 05 Jun 2023 07:00 PM
Sky Q box not receiving internet connection
Message on TV says it looks like you do not have Internet connection right now
Second box says there is problem with network setup
I have held WPS as suggested no luck
