11
This discussion topic has been answered Discussion topic: Sky Q News remote stopped working completely
This message was authored by: Gemmamac87
Hello hoping for some help,
I recently had to change my tv and was getting round to pairing the remote today to allow the volume to be controlled however my sky q remote has stopped working altogether, have switched off at the wall and also rebooted the box, have followed guide for re-pairing the remote but the message does not appear on screen as directed or work to fix the issue. Have also changed batteries but this was not the issue as lights still working.
Re: Sky Q News remote stopped working completely
@Gemmamac87 wrote:
@oldfella yes green light on the box and the remote flashes when doing the 7 and 9 thing.
I've downloaded a remote app in the meantime and the box and everything is working ok so presuming just an issue with the remote.
Hi @Gemmamac87
Make sure that the Q box Infrared sensor is not hidden from the Remote when you press 1 & 3 together.
If the remote LED flashed 4 times with 7 & 9 then the remote should work the Q box by Infrared.  However It will not be Bluetooth and therefore need direct line of sight to the Q Box infrared sensor
Hi @Gemmamac87
Did you complete the following?
Try completly resetting your Bluetooth remote.
Avatar for Gemmamac87
@oldfella hello,
yes I've tried this a few times but don't get the message on screen and remote still remains the same.
@Gemmamac87 wrote:
@oldfella hello,
Hi @Gemmamac87
Assume your Q box is on with Green Led?
Also your TV set switched to the correct HDMI input for you Q box?
Does the Remote led flash 4 times when you press and hold 7 & 9 together?
Hi @Gemmamac87
@oldfella your a genuius
thank you, the door was closed on the tv cabinet all now sorted 😊
This message was authored by: maxymalone
my sky q remote won't work
@maxymalone
After checking the basics, ie; fresh batteries, re-pairing (as above) etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well you’ll have a spare.
This message was authored by: Jeaniner9
Tried all the above but remote still not working and when press 1 and 3 flashes lots?
This message was authored by: LesleyB7
I'm having the same problem! When I press 1 and 3 it flashes lots and no on screen message.
This message was authored by: Karltate
I have the same issue, samsung qled TV, brand new box and remote.
