Discussion topic: Sky Q Mini box. Main box - repeater - mini box all show connected ticks and lights in all the boxes
Message posted on 30 Nov 2024 12:05 PM
All settings boxes ticked Mini box says connected to main box. Message says waiting for TV schedule. Small screen in left corner says technical fault. help please.
Message posted on 30 Nov 2024 12:34 PM - last edited: 30 Nov 2024 12:36 PM
Re: Sky Q Mini box. Main box - repeater - mini box all show connected ticks and lights in all the bo
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the minis. Start with the one nearest to the main Q box or your connected Q booster.
If you are on Sky Broadband and the Router or your connected booster is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
