Discussion topic: Sky Q Mini Boxes wont stay connected to new Virgin Broadband
This message was authored by: CY79
I have been a Sky Broadband customer for several years but they were unable to provide me with the top mbps package and as such I switched to the Virgin Media 1Gig Broadband. I've connected the main Sky Q box to the router with an ethernet cable but none of my 3 mini boxes will connect and hold the connection. Tried all on/off and reset options to no avail. Any ideas most welcome.
This message was authored by: Liveyoung
Re: Sky Q Mini Boxes wont stay connected to new Virgin Broadband
I updated my boxes in settings and it worked after that but I had the same problem when I switched.
Avatar for CY79
What did you update in settings?
hi @CY79
There is a difference in how the minis connect when you are with SKY vs 3rd parties.
When your home wifi is not SKY then the minis do not connect your home wifi but instead use a wifi signal generated by the SKY Q main box which may then extend via the minis
You probably need to reset the network connections in the minis and when asked to press the WPS then it is the WPS button on the main box
And if the Q is in a different location from the router, it might be that the wifi signal is too weak from mini to Q but was ok from mini to the old router.
