3
This discussion topic has been answered Discussion topic: Sky Q Mini Box won't turn off or respond to the remote.
This message was authored by: kirangathani
The Sky Q Mini box has a green light on it, and stays green even when I hold down the button with the green light on or press the button.
I have put new batteries in the remote. The remote can affect the TV itself - able to turn the TV on/off by holding, and the source button works as well. The issue is (I think) specifically with the Sky Q box's ability to recognise commands by the remote.
I have tried the reset I see mentioned elsewhere: pressing 7 & 9 together, waiting for the red dot to flash, then pressing 1 & 3 together whilst pointing the remote at the TV to try and repair but not getting anywhere. Furthermore, since I have done this the remote no longer seems to be successfully operating the TV itself (holding down the power button no longer turning the TV itself on or off).
Any help would be much appreciated!
Re: Sky Q Mini Box won't turn off or respond to the remote.
Hi @kirangathani
Have you tried rebooting the mini
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
When you pressed 7 & 9 on the remote,   this removed it's Bluetooth connection to the mini.
When the mine is back on after the reboot try completly resetting your mini Bluetooth remote again.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Hi @kirangathani
Avatar for kirangathani
This works, thanks!
This works! Thanks
