Discussion topic: Sky Q - Live tv, recordings and streaming apps crashing...
Message posted on 21 Oct 2024 04:02 PM
Sky Q - Live tv, recordings and streaming apps crashing...by this I mean we can be watching a while then out of nowhere the screen blanks (black screen), sometimes it will flick back to the picture and carry on then repeat again moments later or we have to exit and select the show/app again!
I had an engineer booked for today, but he's a no show and after looking at my account there is no booking showing 🤦🏼♂️
Using the Sky VA, this suggests I do a hardware replacement...Is this free of charge?
TIA!
Message posted on 21 Oct 2024 04:17 PM
Re: Sky Q - Live tv, recordings and streaming apps crashing...
TIA!
Hi @RichQ
Message posted on 21 Oct 2024 04:19 PM
Thanks, but I have already tried this 😔
Message posted on 28 Oct 2024 02:13 PM
Don't suppose you're on EE broadband are you? If so, there is a recurrent compatability issue which I've seen in hundreds of threads across the community. We're at the end of our tether with it and the stock response from some mods has been Sky are unable to replicate. Sorry, I don't have an answer, we're in the same boat and I fear II now have a decision to make between EE bb and Sky TV! Hope you get sorted.
Message posted on 28 Oct 2024 02:47 PM
No, I'm actually on Sky full fibre (fairly recent upgrade!)
SKY replaced the box and we've still had the issue crop up!
it's possible that it's interference from audio/visual settings - even though I'd not changed ours perviously, I've taken all Dolby sound settings off as I've only got a Sony Sound bar at the moment! Also test different visuals, my tv was set to 1080p, seems better on 1080i or vice-versa I can't remember!!
Message posted on 23 Mar 2025 04:10 PM
Did you get to the bottom of this as we're experiencing this too. All through the apps, not when watching 'native' Sky channels
