Discussion topic: Sky Q Ethernet signal improvement question
This message was authored by: C7020
Currently running Sky Q, Broadband rounter, booster and 3 Q minis.
Our house is long with broadband route at one end and Sky Q main box at the other (hence the booster).
There are a couple of solid walls the signal has to negotiate, but the booster helps in that regard - to a point.  The signal can be quite poor at times and drops outs frequently when using apps and the furthest Mini box only works for a short while before picture stutter and loss of signal all togther. (Ironically, this one is just a few feet away from the router!)
My hopeful solution is run an ethernet link between the Router and the main Q box. (and to one of the Mini boxes).
Is this likely to improve signal stability rather than relying on the wifi?
This message was authored by: ksaro1
Re: Sky Q Ethernet signal improvement question
Yes, this will make a big difference to watching on the Sky Q main box. However, your mini boxes will still rely on WiFi. So, the issues you mention with the mini boxes will remain. Can you wire them to ethernet too?
Avatar for C7020
I could certainly use a two-into-one ethernet cable from the router to one of the boxes.
This message was authored by: TwoBit
I switched ages ago from Sky broadband to Virgin fibre but was still having wifi issues, due to being an old house with solid walls. In the garden I basically got no signal.
I bought myself 5 Deco M5 discs when they were on offer and created a mesh network. The router now runs as a modem with 1 deco disc plugged into it, the rest run via wifi. Since I've set up the mesh network I even get 80mb/s wifi connection at the bottom of the garden (on M350 package).
My mini box was struggling for connection until I plugged it via ethernet into one of the discs, but I think that was down to the settings, I've not tried changing as all works well.
An option for you.
Avatar for C7020
I do a Deco 3 Mesh system running offf the router as well, on a different network, to run the ancillaries (Computers, ipads printers and other family linked stuff) so as not to clutter the sky Q network.
This message was authored by: Fergus+MacRoth
I did exactly what you have suggested, and it works perfectly.
I'm with Virgin Media, but in any case had switched that to modem mode so I could use a more powerful router. But even between two bedrooms (one brick wall in the way) the Wi-fi connection was unreliable, with the mini box often going offline. Even the main Q box would sometimes struggle, even though it was only a couple of metres away from the router.
I wired both boxes to my home network and haven't looked back.
I hate Wi-fi.
FM
Avatar for C7020
Thank you all for your help and thoughts.  Will put into practice and see what happens.  Will post the result in due course.
