Discussion topic: Sky Q ES340daIT 1TB available space for records
This message was authored by: JoeIT
Hello
I have read that with 1TB the available space should be 700GB but if i check on records / memory with a totale of 204GB of records  the busy space is reported as 48% that mean lesse than 500GB available for records
Whats real number?
I'm from Italy but i suppose that the same model work here as in England
Re: Sky Q ES340daIT 1TB available space for records
@JoeIT
We won't know whether the spec is the same as in Italy. You perhaps need to contact Sky Italia.
Avatar for JoeIT
Thanks for answer. Unfortunately the level of support in Italy is zero practises when you contact the chat they don't know absolutely anything and the only things they recommend is to disconnect the power and try again or ask for the replacement of the decoder 😂. There is no technical suppor.
Same here 😁
See if someone knows here...  UK Spec sheet says the same: https://static.skyassets.com/contentstack/assets/blt7f2b03fd02c7fe60/blt3549f3a28fe38568/62d006b5e1e...
