Discussion topic: Sky Q Boxes up stairs are not connecting to Sky Q box down stairs
This message was authored by: Jasp08
Sky Q box is not connecting to mini box s upstairs
Re: Sky Q Boxes up stairs are not connecting to Sky Q box down stairs
Hi @Jasp08 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
The Mini box connects to the main SKYQ box, not the other way round.
Hi @Jasp08
Try a Network Reset on the mini.
