Discussion topic: Sky Q Box won’t stay connected to broadband
This message was authored by: Anita0607
My Sky Q Box keeps disconnecting and re-connecting to the Network (on a permanent cycle every 10 - 30 seconds). Making it impossible to watch any on demand programs on the the Sky Q Box or any mini boxes.
Re: Sky Q Box won’t stay connected to broadband
Hi @Anita0607
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
