Discussion topic: Sky Q Box not connecting to wifi
Message posted on 06 Oct 2025 06:50 PM
Message posted on 06 Oct 2025 07:10 PM
							Re: Sky Q Box not connecting to wifi
@MH177 wrote:
Help out sky Q box keeps losing the WiFi signal even though our WiFi is on and in use on all other devices including standard tv. Why?
Hi @MH177
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 06 Oct 2025 10:51 PM
