3
This discussion topic has been answered Discussion topic: Sky Q Box. Whenever I try to play anything, the screen goes black or blue
This message was authored by: laurenn23
Whenever I try to play anything, the screen goes black or blue and there is no picture or sound and the playback does not start. ,
This is the same for any type of programme - live tv, recordings, on-demand, as well as apps like Netflix and Spotify.
The screen and everything works fine when browsing the guide and apps but if I click on something for it to play then the screen will go black or blue. I can press the back or home button and then the screen returns but nothing will play at all.
I have tried turning everything off by the mains but I cannot find any solution to this
Please help, would be appreciated 🙂
Re: Sky Q Box. Whenever I try to play anything, the screen goes black or blue
Hi @laurenn23
Hi @laurenn23
Avatar for laurenn23
Thank you, this worked.
This message was authored by: KazzaGB
My tv goes black when I go onto any program. Tried switching off
