Discussion topic: Sky Q 2 TB box connected to router but not to internet.
This message was authored by: timdavies
My Sky Q 2 Tb box will connect to internet fine if hard wired but using WIFI option it sees the Router fine but no connection to internet. Am i eleigible for a replacement box at no cost as hard wiring it is inconvenient ?
Re: Sky Q 2 TB box connected to router but not to internet.
Hi @timdavies
Remove the Ethernet.
Then  reset your broadband router.
Avatar for timdavies
Level 2 icon
Yeah,  already done all that have about 10 devices connected to the virgin router fine on 500 Meg bb , if I went back to ADSL would be on 45 Meg. @oldfella
Hi @timdavies
500 Mbps is completely irrelevant for Sky Q.
maximum it really needs is 60 Mbps to give a decent Download speed for movies. 30Mbps is enough for 4K.
