Discussion topic: Sky Multiroom not working says Tehnical fault, we are connected to the internet
Message posted on 05 Jul 2023 07:36 PM
Watch TV all afternoon switched it off then when switched back on says Unable to watch TV as there is a Technical Fault, checked the internet and all ticked, any ideas please
Message posted on 05 Jul 2023 08:06 PM
Re: Sky Multiroom not working says Tehnical fault, we are connected to the internet
Hi @Twisty
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
