Discussion topic: Sky Mini Q picture freezes, slow to change channel
This message was authored by: NaW17
I have Sky Q and 2 X Mini's, about 2 years old.  1 of the mini's is the issue after about 3 mins of watching sky channel's
  • pictures freeze
  • wont change channel
The wifi connection seems ok as can watch Netflix/Prime via the Smart TV app's with no issue.  I have unplugged the mini Q and left it off power for 8+ hours but when plugged back in and rebooted  after about 5 mins the same "stuttering" of picture and inability to switch channels happens.
Any suggestions or is it a "long wait" call to Sky?  Thanks
Re: Sky Mini Q picture freezes, slow to change channel
  • pictures freeze
Hi @NaW17
Your WiFi Network is irrelevant to mini use unless you are on Sky Broadband.   On 3rd party broadband minis connect to WiFi generated by the main Q box.
You could try swapping the two minis around and see if the issue is with a oarticukar mini or it's location.
Avatar for NaW17
Thanks to oldfella for teh comment.  My broadband is from SKY aswell and as I mentioned the Apps on the Smart TV work fine.  My view is the mini Q has a fault.  Does anyone know how to log a fault call with Sky?
@NaW17 Have you tried @oldfella suggestion of swapping the mini boxes over to see if it's the location or the box ?  You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
This message was authored by: Tom-W19
Hi @NaW17
Have you tried resetting the network connection on the affected Mini and going through the process of reconnecting the Mini to your Main Q box?
Tom
