Discussion topic: Sky MINIQ box can’t get pass settings to set up
24 Dec 2024 04:26 PM
We have 2x mini skyQ box's one in kitchen one in bedroom do everything as instructed. but can't get pass settings
24 Dec 2024 04:39 PM
hi @SSALMON
If you are seeing a message regarding accessibility then try the followimg (might also work if not):
Press & hold 4 & 6 on the remote to set to Infrared only
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
