Discussion topic: Sky Full fibre
Message posted on 03 May 2025 02:43 PM
Sky Full fibre
I have just had full fibre fitted and am wondering if I should now disconnect the sattelite cables that are connected to the back of the Q box.
Also, would it be a good idea to connect the TV or the Q box to the new router with an ethernet cable.
many thank.s
Message posted on 03 May 2025 02:49 PM
Re: Sky Full fibre
@iggledypiggledy wrote:I have just had full fibre fitted and am wondering if I should now disconnect the sattelite cables that are connected to the back of the Q box.
Why would you do that? It will stop working... Q requires a satellite feed.
If cabling is an option it is almost always a better option than using WiFi.
Message posted on 03 May 2025 02:52 PM
Re: Sky Full fibre
The reason that I asked is that the guy who fitted my full fibre yesterday to me the when full fibre is fitted then everything is Wi-Fi and Sky dishes become obsolete.
Message posted on 03 May 2025 03:04 PM - last edited: 03 May 2025 03:05 PM
Re: Sky Full fibre
Simply incorrect, and rather worrying that they might think that.
The dishless Sky television platform is Glass/Stream. Sky Q is a satellite system.
Message posted on 03 May 2025 03:05 PM
Re: Sky Full fibre
@iggledypiggledy wrote:The reason that I asked is that the guy who fitted my full fibre yesterday to me the when full fibre is fitted then everything is Wi-Fi and Sky dishes become obsolete.
He told you false information.
Sky Q is a satellite delivered service. Without the dish and cabling your Q box would be useless.
Sky Stream is the completely separate and totally different TV service which operates entirely using broadband. It doesn't need full fibre though, it can function with old school broadband too, as long as it is fast and stable enough.
Message posted on 03 May 2025 03:10 PM - last edited: 03 May 2025 03:11 PM
Re: Sky Full fibre
Being charitable then that's possible - either by switching to a non-satellite service (e.g. stream) or if the fibre is FIRS (that carries the satellite signal but is rare such as OFNL https://www.ofnl.co.uk/wp-content/uploads/2022/08/OFNL-FIRS-Leaflet.pdf).
Message posted on 03 May 2025 07:05 PM
Re: Sky Full fibre
Hi any other person who has got sky q what do you think of it
Message posted on 03 May 2025 07:37 PM - last edited: 03 May 2025 09:24 PM
Re: Sky Full fibre
Sky Q was released in February 2016 and has been in use by millions of households in the near decade since then.
It's important to note that satellite television broadcasting is probably approaching the end of its life as a technology, and Q was followed by Glass & Stream from late 2021 onwards.
Message posted on 03 May 2025 09:01 PM
Re: Sky Full fibre
