Discussion topic: Sky F1 playing on SkyGo but not on TV, Sky Sports subscription says active
This message was authored by: writestuff
My Sky Sports subscription says active in my account but the channel won't play on the TV. Says I'm not subscribed. It plays on SkyGo on laptop.
Re: Sky F1 playing on SkyGo but not on TV, Sky Sports subscription says active
@writestuff Have you tried rebooting your main Q box ie
or
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
