Discussion topic: Sky Extender shows power and Wi-Fi to be green but fails to connect
This message was authored by: HughH1
The mini Sky Q box is not working presumably because it is not connected to the Sky Extender. I have BT broadband that is working well. The main Sky Q box is working as it should. I have tried placing the Extender close to the BT router but still only get two of the three green lights - power and Wi-Fi green but no light re Connection.
How do I re establish a Connection? I have attempted to Reset multiple times? I assuming that when a connection is made with three green lights, then the mini Q box will work!?
Re: Sky Extender shows power and Wi-Fi to be green but fails to connect
@HughH1 If you have a Sky booster then you need to connect the booster to you main Q box by pressing the WPS button on both boxes then connect the booster to your mini box
It won't connect to your router by wifi
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
