Discussion topic: Sky Cinema gone, asking me to upgrade
Message posted on 09 Nov 2025 05:29 PM
Hi
I signed up to sky cinema for a year on 25th October, found out yesterday the channels are gone and is asking me to upgrade. Found lots of threads of this in the forums but no solution.
Done a software reset
Also Plugged the sky Q box out for 30 secs and in again
No joy
Please advise
Message posted on 09 Nov 2025 08:05 PM
Re: Sky Cinema gone, asking me to upgrade
@Cian85 wrote:
Hi
No joy
Please advise
@Cian85 have you checked on the my sky app or your Q box that Sky cinema is still showing as part of your subscription
Message posted on 09 Nov 2025 08:35 PM
Yes, it says its still active along with paramount +
Message posted on 09 Nov 2025 08:46 PM
@Cian85 2 things to try if you hanen't already
first
Have you tried rebooting your main Q box ie
second
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
failing that you would have to contact sky
Message posted on 10 Nov 2025 04:10 PM
Contacted sky and the problem still persists. I dont think the lady on the phone really understood what I was talking about. Can this be sorted by a Sky tech here?
Message posted on 10 Nov 2025 04:30 PM
@Cian85 afraid we are customers like yourself, this is a customer to customer forum where customers help each other. Afraid you will need to persevere with contacting Sky
