2
This discussion topic has been answered Discussion topic: Sky Cinema UHD but no longer HDR??
This message was authored by: ianmerseyside
I have previously downloaded many movies from Sky Cinema in UHD HDR and still have a few saved in this format.  However, I can no longer see any available in HDR within Sky Cinema, only UHD.  The only movies I can spot in UHD HDR are all in the Sky Store.  Has there been a recent change?  My settings are fine as I can still watch/record foorball in UHD HDR, as well as some shows like Gangs of London.
Avatar for ianmerseyside
Level 7 icon
This message was authored by: ianmerseyside Answer
Re: Sky Cinema UHD but no longer HDR??
Thanks @oldfella .  Yes, they are indeed all showing as HDR.  There must have been a glitch at my end as when I checked earlier, every movie within the UHD option was only SDR.  Issue solved! 😊
Just checked here @ianmerseyside
Quite a few in HDR.
Harold and the purple crayon
Maxxxxine
The killer
Bad boys
etc.
 Edit
looks like you may be set to 2160 8 bit instead of 10bit
Level 7 icon
