Discussion topic: Sky Cinema HD Channels only, are pixelated.
This message was authored by: Gray+Boy
Signal Strength 80
Signal Quality 90
Have only just enabled thesechannels, and have performed the suggested Sky Q box reset.
Any suggestions would be most welcome.
Re: Sky Cinema HD Channels only, are pixelated.
@Gray+Boy wrote:
Signal Strength 80
Signal Quality 90
Hi @Gray+Boy
The Signal strength on Q is not indicative of the channel you are watching as it is taken from just one random transponder.
What do you mean when you say you have only just enabled these channels ?
Avatar for Gray+Boy
Just taken Sky Cinema subscription.
Avatar for Gray+Boy
Confused because all the other HD channels seem to be okay.
Hi @Gray+Boy
If the issue continues then it's best to a Sky Engineer to check your Satellite dish alignment.
Minor dish misalignment will not necessarily affect all channels  and the ones with the weakest signals will be the first affected.
Avatar for Gray+Boy
Hello @oldfella @
Thanks for your help.
That seems the only option I have left, as I've tried all the other suggestions to no avail.
