Discussion topic: SkYQ mini - WIFI - I'm connected but some websites/apps won't load
This message was authored by S1D5 This message was authored by: S1D5
Hi, I've just had Litfibre installed. I've connected my main SkyQ box via ethernet to the router. 1 SkyQ mini is also connected via ethernet cable. The other two via wifi.
I have turned on the option to use the mini's to boost my WIFI signal.
Using the SkyQ mini connected by ethernet, I can connect to my main home network, however I cannot get all websites or apps on my phone to work.
bbc.co.uk & google.co.uk &duckduckgo etc....- This site cannot be reached
Facebook & Amazon apps work fine
I'm using a Samsung galaxy S23 ultra. I have an old Amazon fire tablet and when I connect through this, I can access bbc & google websites with no problem.
Litfibre are telling me not a problem at their end?
I used to have this setup using BT and it all worked fine...
Any ideas how I solve this?
S1D5
Re: SkYQ mini - WIFI - I'm connected but some websites/apps won't load
By way of an update, I can ping the websites and get all packets back. I just can't get a response through the web browser or apps?
This applies on my laptop and phone......
This message was authored by Patrick30 This message was authored by: Patrick30
I have an identical problem Have you found a solution?
S1D5
No I gave up in the end. I bought a v.cheap BT home hub and used that in wifi mode instead to create a new wifi newwork.
