Discussion topic: Since sky q has been installed i cant get multi room. We dont have interent
This message was authored by: Michelle3333
Hi, Since Sky Q was installed. I cant get multi room as our Internet is only 1mb. (The area I live in has bad Internet)
How can I get sky in the other room with-out Internet?
Re: Since sky q has been installed i cant get multi room. We dont have interent
Hi @Michelle3333 Click on the link Here to help with whats available to you.
Avatar for Michelle3333
Sadly that doesn't help. That just helps if you have Internet or broadband in the house. But thank you
As you have Q then a mini box (and multiroom sub) will work.  It doesn't use your internet connection for the main box and mini to connect to each other.
Sadly I was told you have to have Internet for th sky mini box to work. I did try and it doesn't work with-out Internet.
I always believed that it needed a router and an internet connection to complete the initial setup. Once that's done it doesn't use the internet as such.
Did Sky come and install Sky Q?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
hi @Michelle3333
Once it has been activated then you should not need an internet connection - but see the section on the link that @Quoman7 gave regarding it's restrictions.
Assuming it was properly activated on installation then I think your problem is just the connection between the mini & your main box.
It uses wifi although it can also (more reliably) use ethernet cables
it does need an active router but does not rely on that having a stable / good internet connection.
Is your router always on ?
Who is your internet provider (albeit poor) ?
If it is not SKY then it will not use your home wifi but will use a wifi signal generated by the main box so it will depend on where all your boxes are located and any possible sources of interference
That is so helpful. Thank you so much.
