Discussion topic: Since Sky Q installation, other TV’s in house have no signal
Message posted on 09 Sep 2024 09:28 PM
Sky Q was installed. Main box is working.
Digital TV's in other rooms no longer have any signal/snowy picture when switched on.
Sky Q technical advisors have not been able to help.
Message posted on 09 Sep 2024 09:32 PM
Re: Since Sky Q installation, other TV’s in house have no signal
Hi @Skyq7
There is not any RF (terrestrial outputs ) on Sky Q so you will have lost the ability to use the Q box for RF out.
You will need to buy a simple powered aerial splitter to take the input from your terrestrial aerial and feed it to your main TV and also to the other Televisions.
Something like the following
Message posted on 09 Sep 2024 09:38 PM
Thank you. I have had so many calls with Sky and not one adviser could offer any help. I'll try that
Message posted on 09 Sep 2024 09:56 PM
You may be able to simply connect the RF in to the RF out connection that was previously in the Sky HD box.
Sky Q installers will not touch RF cables as part of the installation. But as noted the Sky HD box had RF in and out connectors.
Message posted on 09 Sep 2024 10:00 PM
Thanks for your help. I'll take a look and try that
Message posted on 18 Sep 2024 11:13 AM
