Discussion topic: Simple request to add sky sports.
This message was authored by: Tex11
Simply ask how much to add sky sports to my existing package. It would not give me an answer. Kept directing me to absolutely nothing to do with what I ask for.
Re: Simple request to add sky sports.
@Tex11  Have you tried adding it through your account at sky.com?
This message was authored by: bouncee
I have same problem.
There is a link to add sky ports for £22 pm (reduced from £31 pm) but when I click on it, it says sky sports premier league and if I check out it is £20 pm  extra
@bouncee
Contact Sky and ask an agent to apply it for you.
These are the current methods for contacting Sky…
🔹call Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline.
All calls will start automated which may offer you the online help route (see below) or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔹online help via this link
https://www.sky.com/help
At the end of the help it MAY provide a phone number if it's appropriate.
🔹 Sky Assistant is now available at the top of sky.com/help for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
🔹Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Hi @bouncee   The full package is £40 list and is called Sky Sports Complete including Sky Sports+. That definitely sounds like just one channel which is poor value.
Thanks for the help.
I phoned Sky and they added Sky Sports for £20 pm, at the same time took £5 off basic Sky TV.
