Discussion topic: Signal issue ok with sat finder plugged into lnb, but when I power the finder off, I also lose signa
Message posted on 29 Sep 2023 02:48 PM
Hi , I am a seasoned sky caravannet, on my last outing, I aligned my dish using my finder and got a good signal (it has a buildt in receiver and is tuned to SC4 on Astra 2).
The signal was good in the caravan on the sky Q box. But when I removed the finder I lost the signal in the can. This was repeatable, switching on and signal reappeared. It is as if the lnb was getting no power from the sky box? O have changed the lnb and still the same?
Message posted on 29 Sep 2023 03:12 PM - last edited: 29 Sep 2023 03:13 PM
Re: Signal issue ok with sat finder plugged into lnb, but when I power the finder off, I also lose s
Do you have a Hybrid or Smart LNB or a dSCR capable LNB - SKY Q uses a different frequency range to Universal LNBs that Satfinders & other Freesat Box (& SKY HD boxes) use
(BTW Maybe I should mention the T&Cs regarding where you can use your box)
Message posted on 29 Sep 2023 03:16 PM
I have a hybrid (2 gold for sky Q, and 4 regular) , I have used this setup for years with no issue, just odd that it works with the sat alignment device powered up, but not with it powered down.
Message posted on 29 Sep 2023 03:21 PM - last edited: 29 Sep 2023 03:23 PM
mm strange - Personally I would expect each LNB to rely on it's own power and certainly wouldn't expect any cross from the Universal inputs to the Wideband inputs.
Just out of interest did you check both polarities on Q (each cable carrying one) ?
Message posted on 29 Sep 2023 03:26 PM
Thanks for the reply, I didn't. I did check continuity on both inner and outers. I'll try that tomorrow. Box back under the telly and working fine. I"m using the blue flexible cable from Maxview but continuity was fine.
Message posted on 29 Sep 2023 04:39 PM
@ChrisGalletly just to pick up again on what @nigea99 mentioned it is against your T& C's to use your Sky viewing card/equipment away from your registered address so seeking advice on a Sky run forum is not the best thing to do
Message posted on 01 Oct 2023 12:56 PM
I am using it at my registered address, the caravan is currently on the drive, but thanks for your helpful reply.
Message posted on 07 Feb 2025 07:39 PM
No signal since storm
Message posted on 07 Feb 2025 07:47 PM
No signal but have WiFi
Message posted on 07 Feb 2025 07:59 PM
Hi @Colinbrash You need to contact Sky and arrange an installer visit. Could be a very long wait (due to the recent storms!).
Message posted on 09 Feb 2025 10:05 PM
It was a fault in the cable, but thanks for your reply.
