Discussion topic: Signal in one of my home rooms
This message was authored by: Scott091
Having trouble with my WiFi in one of my rooms at home don't seem to.get a signal in my back room and can't get wife to use my TV all other rooms are fine
Re: Signal in one of my home rooms
Hi @Scott091
Assume this is on a mini box.
First
Reboot the mini as above.
Also if another connected mini is nearest to the problem mini you can try using WPS on the nearest mini.
