1
This discussion topic has been answered Discussion topic: Sick of no satellite signal again
This message was authored by: Wes11621
I'm really sick of this happening.  When there is a little bit of wind the satellite signal goes down. I reported this a number of weeks ago and an engineer called, he checked the satellite dish and and sky q box apparently everything was ok.
Re: Sick of no satellite signal again
@Wes11621
You need to call again. If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@Wes11621
Answered - Go to Answer
