Discussion topic: Should I switch my main box to my bedroom if I use it more
This message was authored by: Calebk231
I have the main box in the living room and barely use it and the sky q in my bedroom and use it all the time, my WiFi is slow would it make it any better if I was to switch them?
Re: Should I switch my main box to my bedroom if I use it more
@Calebk231  Where's the router located?
the closest devices are to it you're likely to get a better signal but no guarantee
This message was authored by: ftballman
The main box needs to be connected to the cables coming from the satellite dish. That's the biggest thing that will dictate whether you can move it or not.
Hi @Calebk231
If you are going to re locate your main Q box you must also bear in mind that the twin cables from the dish must go to the main box .
