Discussion topic: Setting up sky q mini box stuck on your sky remote is now set up
This message was authored by: Codicote
Sky q mini box is not going past finish so u am unable to continue setting up, it has been stuck for 15 minutes
Re: Setting up sky q mini box stuck on your sky remote is now set up
@Codicote Have you tried rebooting your main Q box ie
then
reboot your mini box
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
