Discussion topic: Second sky box - tv has message “check your sky subscription entitles you to view on this box.
Message posted on 28 Oct 2023 09:56 PM
Second sky box - tv has message “check your sky subscription entitles you to view on this box. Otherwise if you're using this box for the first tube, please wait a few minutes"
Message posted on 28 Oct 2023 10:22 PM
Re: Second sky box - tv has message “check your sky subscription entitles you to view on this box.
Hi @SarahKucera
Reboot the mini as above.
