Discussion topic: Second sky box has no signal
Message posted on 17 Nov 2024 09:23 PM
I have a second skybox upstairs in the bedroom. It's showing no signal. We cannot get it to work. If we do finally get something come up, he asked for us to check Settings but you cannot move across to ask later. There's just no signal.
Message posted on 17 Nov 2024 09:28 PM
Re: Second sky box has no signal
Hi @Help2024
Reboot the mini as above.
