Discussion topic: Screen stuck on you will be ready to go in a couple of minutes
This message was authored by: AngelaFergal
Re: Screen stuck on you will be ready to go in a couple of minutes
Hi @AngelaFergal
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
This message was authored by: Henry871
My sky box is also stuck on this tried rebooting the sky q box still stuck Iv also had a new sky box delivered to try and resolve this and still stuck !
