Discussion topic: Screen says “ viewing card not paired
Message posted on 25 Mar 2023 07:30 AM
Screen says " viewing card not paired"
Message posted on 25 Mar 2023 08:51 AM
Re: Screen says “ viewing card not paired
Hi @Monread Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
If that doesn't work, try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
