1
This discussion topic has been answered Discussion topic: Screen blanking out, picture freezing, blank screen with audio, sometimes picture works with no audi
This message was authored by: Terry8607
Screen blanking out, picture freezing, blank screen with audio, sometimes picture works with no audio, when playing a recording and fast forwarding the screen freezes.
Re: Screen blanking out, picture freezing, blank screen with audio, sometimes picture works with no
Hi @Terry8607
Hi @Terry8607
