Discussion topic: Says there is a technical fault with this channel please try later
Message posted on 12 Jul 2023 08:13 PM
Message posted on 12 Jul 2023 08:25 PM
Re: Says there is a technical fault with this channel please try later
Hi @Plee217
try rebooting your Q box.
Message posted on 25 Oct 2023 12:37 PM
keeps happening to my box nearly everyday is there a long term fix?
Message posted on 12 Nov 2023 07:34 PM
All the time
Message posted on 18 Nov 2023 11:19 AM
This keeps happening to me also, needa the power removed from the sky stream puck and then when it boots up agian it will work....
Very annoying, stream seem to have many more issues than Sky Q.
Message posted on 27 Apr 2024 01:08 PM
I are trying to change my email address on Sky Q but keeps saying sorry, we're having a technical problem.I have tried for days but with no luck. Please help
Message posted on 15 Sep 2025 10:46 PM
Up to 5 mins to return after all that hassle? Your answer was over 2 years ago and still the same issues in September 2025. Time to switch from Sky Glass, really has been a big disappointment on so many levels.
Message posted on 16 Sep 2025 04:55 AM
The advice from @oldfella was 2 years ago but is still the correct method of rebooting a Sky Q box. If you have a Glass TV you perhaps need to look on the Glass board.
