Discussion topic: Says I'm not subscribed to mini box
Message posted on 08 Nov 2024 06:09 PM
My 3 mini boxes do t work
Message posted on 08 Nov 2024 06:25 PM
Re: Says I'm not subscribed to mini box
Hi @kseacy
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
