Discussion topic: Saying no satellite signal, it’s in a complex and no one else has issues. I have turned everything o
Message posted on 25 Aug 2024 12:53 PM
Saying no satellite signal, I'm in a complex and no one else having a problem. I've tried turning everything off for over 30 seconds and still no signal
Message posted on 25 Aug 2024 12:58 PM - last edited: 25 Aug 2024 12:59 PM
Re: Saying no satellite signal, it’s in a complex and no one else has issues. I have turned everythi
@benmc18
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise check the troubleshooting in this link
As you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 25 Aug 2024 01:00 PM
Hi @benmc18
If on a Communal dish check in your Q box in Settings- Status - Satellite signal - info
You should on SCR LNB and not Wideband.
