Discussion topic: Saying no satellite signal checked satellite nothing in the way.
Message posted on 16 Jan 2024 05:47 PM
No satellite connection
Message posted on 16 Jan 2024 06:01 PM
Re: Saying no satellite signal checked satellite nothing in the way.
You can't see the satellite. It's thousands of miles up. Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
