Discussion topic: Saying No network connection but I have wi fi working on other devices in house?
This message was authored by: Em1973
Saying no network connection but WiFi working on other devices in house?
I've tried re booting sky box and WiFi several times but still the same.
Re: Saying No network connection but I have wi fi working on other devices in house?
Hi @Em1973
Assume this is your main Q box?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
