Discussion topic: Satellite signal not being received every morning wen i wake up
Message posted on 13 Jan 2024 09:09 AM
Since bad weather 3 months ago,nearly every morning I hav to get up and turn my box off then the signal comes back and I hav to put WiFi password back in and match my 2 mini boxes. Most days
Message posted on 13 Jan 2024 11:07 AM
Re: Satellite signal not being received every morning wen i wake up
So are you seeing a 'No satellite signal' error message?
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
