Discussion topic: Samsung TV not turning off
Message posted on 03 Mar 2023 03:21 PM
Hi, I have new Samsung TV and have paired the sky remote to it. It switches on the TV ok and changes volume but will not switch the TV off
I have tried all sort of combinations with power button but cannot get it switch off
Any advice?
Message posted on 03 Mar 2023 03:24 PM
Re: Samsung TV not turning off
Are you holding the power button for 3 seconds?
Message posted on 03 Mar 2023 03:37 PM
Yes. Holding down for 3 seconds just resets the TV. The TV goes off for a spilt second but then reboots
Message posted on 03 Mar 2023 03:43 PM
I recently obtain a Samsung QN90B, a short press will turn off the Qbox, and the longer press of about 3secs, until the white line appears across the display, will turn off the TV. One short press turns on both.
Message posted on 03 Mar 2023 04:20 PM
Hi @Jimmer1611
Maybe your 3 seconds is fractionally too long and you need to try a tad less.
Some Sony TV's will reboot with a long off press.
However I get on fine here with mine with a 1 2 3 off
Message posted on 15 Jun 2023 03:16 PM
I have exactly the same problem, but have not been able to find a solution.
Message posted on 16 Jun 2023 12:15 PM
Yup it's so annoying, I've tried everything with no joy
Message posted on 06 Nov 2023 04:35 PM
i have just spoken to someone at samsung who said my model could not do it. They said the samsung remote could control sky but not the other way around. I have older samsung tvs that do it fine. very annoyiong
Message posted on 17 Feb 2024 01:52 PM
Has anyone found a solution to this yet? I bought a Samsung UE65CU8500 yesterday and am having the very same issue - sky remote will not turn off the TV, just reboots it. Controls the sound and turns on the TV just fine however. Really, really frustrating.
Message posted on 17 Feb 2024 02:28 PM
@Turkish9 have you read the post directly above yours where @JD6 has had a reply from Samsung stating this doesn't work on some of their TV's
Message posted on 17 Feb 2024 02:32 PM
I'm a year in now and still don't know how
I believe it can be done via some combination as I have managed it by mistake and also my child has.
Tried numerous time to replicate what I done without any joy
It's very frustrating
Message posted on 17 Feb 2024 02:38 PM
Yes I did. I was hoping there was perhaps an update so software in either the TV or sky box to get this to work but obviously not.
Funnily enough, when you try to programme your sky remote to work the TV, it asks you if you know the model of your TV. Mine is not in the list.
Message posted on 17 Feb 2024 02:51 PM
@Turkish9 you could try saying its not known then trying all the options it gives you for Samsung unless you have tried that as my LG is not listed but by clicking on the not known option one of the options it gives me works
Message posted on 17 Feb 2024 03:14 PM
Tried all that sadly.
