Discussion topic: Samsung TV and Sky Q connection issued
This message was authored by: Brad18322
Hi.  I have recently purchased a new Samsung TV (50" QN90C Neo QLED 4K HDR Smart). I previously had an older Samsung atV but still QLED and had no issues at all. Since getting the new tv, I have had constant connection issues between tv and sky box. Probably 50% of the time when I turn the tv off and later turn it on, it will tell me there is no connection to sky box and will only reconnect once I manually turn off my sky box at the power. I can see my sky box is turned on but it won't connect no matter whether I disconnect the HDMI, and will only work actually switching the sky box off. This is annoying to say the least! I've seen a few similar issues but can't seem to find whether there has been a fix or not! Please for the love of god someone help me 🙈😩
Re: Samsung TV and Sky Q connection issued
Hi @Brad18322 With both your TV and SKYQ box on standby, turn the SKYQ box on first by pressing the SKY logo button on top of the remote?
Avatar for Brad18322
Thanks. Will give this a go for the next few days and see if it does the trick. 👍
This message was authored by: paultm53
I have a new qn90d 50 inch neo connected to sky q uhd doing exactly the same. Worked well for two days then the problems started. Sky are sending out a new box but I'm not hopeful.  Will I have to send the Samsung back and get a sony / LG/ etc?
Fingers 🤞 tomorrow when I connect up the new box.
