Discussion topic: SKy Q change from 1TB to 2TB box
This message was authored by: RobertT1
Hi, I returned to sky Q last week after cancelling back in August. I have just realised that they have sent me a 1TB box when I really need a 2tb box as I need to connect two minis at the same time. I believe the 1TB only allows 1 mini box at a time. I was about to order a second mini box when I realised the problem. Will they swap my 1TB for a 2TB? (I've only had it a week) thank you
This message was authored by: Nina+JS
What is sky titan?
On my iPhone I have a connected device showing up in WiFi as Sky Titan. Does anyone know what this? Could it be a Q box?
thank you
Re: What is sky titan?
@Nina+JS
Yes, it's an internal code name for one model of Q television box: there's also an X-Wing and a Falcon, so apparently someone within Sky has a copy of a Star Wars encyclopedia...
Thank you 😊
This message was authored by: Tortia
What is sky x-wing
I have a device on my Apple ID listed as Sky X-wing.  Could it be my sky q tv box or is it my family member's Sky HD box ?
Re: What is sky x-wing
@Tortia
Not sure why it would be listed on your Apple ID but Sky X-Wing is an internal codename for a Sky Q product
I am NOT a Sky Employee
@Tortia
Yes: various Star Wars related names have been spotted.
https://helpforum.sky.com/t5/Broadband/What-is-sky-titan/m-p/4317279
This message was authored by: pinknina667
Whats the difference between the different box names please?
@pinknina667
There have been four different main Q boxes versions, plus the Mini box: presumably the different internal code names refer to different models.
@pinknina667 Sky Q was introduced in 2016 since then various versions of the Q boxes have been introduced the early boxes did not support HDR which appeared on a later version. If you ask this question in the Sky Q forum one of the members can give more detail.  .
Thanks both 😊
Re: SKy Q change from 1TB to 2TB box
@RobertT1
A 1TB is the normal Sky Q box now provided.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
The 1TB UHD/HDR box, which permits two Mini boxes in simultaneous use, has been the default hardware since late 2019.  The restriction you refer to is applicable to the non-UHD 1TB dating from the first launch of Q in early 2016.
It has been known for those older 1TB units to be shipped by mistake, though, or where the household doesn't have a UHD subscription.
To check which Sky box you have:
  1. Press Home on your Sky Q remote.
  2. Select Settings followed by System info.
  3. Check your Hardware version and use the table below to see which type of Sky Q box you have.
Hardware version number Type of Sky box UHD-capable? HDR-capable?
32B0xx Sky Q 2TB Yes No
32B1xx Sky Q 2TB Yes Yes
32B2XX Sky Q 1TB UHD or Sky Q 2TB* Yes Yes
32Cxx Sky Q 1TB No No
Avatar for RobertT1
Hi, I have checked and I have a number starting 32C009 which looks like it is a pre 2020 box? Does this mean that box only allows 1 mini?
That's correct.  As I mentioned above, it's not unknown for that rather vintage model to be shipped where the household doesn't have a UHD subscription (or just in error)
