Discussion topic: SKy Q change from 1TB to 2TB box
This message was authored by RobertT1 This message was authored by: RobertT1
Hi, I returned to sky Q last week after cancelling back in August. I have just realised that they have sent me a 1TB box when I really need a 2tb box as I need to connect two minis at the same time. I believe the 1TB only allows 1 mini box at a time. I was about to order a second mini box when I realised the problem. Will they swap my 1TB for a 2TB? (I've only had it a week) thank you
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: SKy Q change from 1TB to 2TB box
@RobertT1
A 1TB is the normal Sky Q box now provided.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
The 1TB UHD/HDR box, which permits two Mini boxes in simultaneous use, has been the default hardware since late 2019.  The restriction you refer to is applicable to the non-UHD 1TB dating from the first launch of Q in early 2016.
It has been known for those older 1TB units to be shipped by mistake, though, or where the household doesn't have a UHD subscription.
To check which Sky box you have:
  1. Press Home on your Sky Q remote.
  2. Select Settings followed by System info.
  3. Check your Hardware version and use the table below to see which type of Sky Q box you have.
Hardware version number Type of Sky box UHD-capable? HDR-capable?
32B0xx Sky Q 2TB Yes No
32B1xx Sky Q 2TB Yes Yes
32B2XX Sky Q 1TB UHD or Sky Q 2TB* Yes Yes
32Cxx Sky Q 1TB No No
RobertT1
Hi, I have checked and I have a number starting 32C009 which looks like it is a pre 2020 box? Does this mean that box only allows 1 mini?
That's correct.  As I mentioned above, it's not unknown for that rather vintage model to be shipped where the household doesn't have a UHD subscription (or just in error)
RobertT1
Ok thank you.
would I just need to call them to try get a newer box?
I want a 2nd mini at the same time, they sent me one as part of me returning and taking out multi room. No point getting a 2nd mini if I can't use them both at the same time.
Yes: they'll probably want to charge a fee, so I'd suggest you negotiate based on the age of that hardware, its lack of HDR support and your intended Mini use.
RobertT1
Thank you
This message was authored by Gem3001 This message was authored by: Gem3001
I've just checked and our hardware version is none of these it says 32DOAD What does that mean?
@Gem3001
32Dxx is the mini box.
@Daniel0210 wrote:
@Gem3001
I edited the table to remove the Mini, as that wasn't the subject of the original post.
This message was authored by DaiapGymru This message was authored by: DaiapGymru
I found Timmy's reply about disc size very helpful. My hardware version is 32B206, but the table shows that it could be 1TB or 2TB with an asterisk at the end. I wasn't sure what the asterisk refers to so still not sure what size my disc is. Could anybody enlighten me?
This message was authored by MightyQuinn This message was authored by: MightyQuinn
Hi @DaiapGymru   The following link explains, including how to find if you have a 1TB or 2TB box.
https://www.sky.com/help/articles/sky-software-updates
Got it thanks MQ, it's a 1TB box. Who'd have thought you'd find this under the music section?!
thanks for your help.
