Discussion topic: SKYQ not working in multi room
Message posted on 24 Feb 2024 11:33 AM
My newly installed SkyQ not connecting to multi room recover or connect to 3 party internet
Internet fictions properly and correctly as an important custermer its is shocking that SKY
making think of ending my contract as SKY is not interested in providing the service as agree
Message posted on 24 Feb 2024 11:39 AM
Re: SKYQ not working in multi room
What happens when you try to do a network reset on the Q to re-attach it to the router's wifi?
Message posted on 24 Feb 2024 11:42 AM
Hi @John474
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home.
First thing to try with your issues is reset your broadband router.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
If you get the main Q box connected then you concentrate on your Multiroom box.
Reboot the mini as above.
