Discussion topic: SKYQ BOX have to turn off power to get it to switch on
Message posted on 06 May 2026 05:51 PM
Sky Q box goes in standby with remote with tv aswell but will not come on again unless we disconnect power then switch it on again then it goes through the setup again. Sometimes it doesn't happen.
Message posted on 06 May 2026 07:14 PM
Re: SKYQ BOX have to turn off power to get it to switch on
Hi @David6011
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 06 May 2026 08:02 PM
