2
This discussion topic has been answered Discussion topic: SKY Sports UHD close up camera picture issues
This message was authored by: Gw9
Hi, anyone help with this.   I have started to get ghost or shadows on close up camera (not all camera shots) for the Sky and BT UHD channels -  the issue is only on Sports channels and does not happen on Sky movies in UHD films for instance so im ruling out my tv being the issue.  I have a Samsung which is 10 bit and even if i change to 8 bit it still shows in the close up camera on screen ie when Sky show the main screen or use the main camera, no issue, lets say someone scores a goal, they go close up, and i see the shadow. I had a mate over to watch a game and he remarked on it too.   Bizarre?   Any help pls ive tried all the standard stuff, wires, reboot, switch off etc etct
Avatar for Gw9
This message was authored by: Gw9 Answer
Re: SKY Sports UHD close up camera picture issues
Hi thanks but that hasnt solved the issue, i wonder if this is a Sky issue on sports . I watched a UHD film last night and it was perfect. Watch the cricket and on the close up camera with sharpness at 0 its shadowy
@Gw9  Check the sharpness level setting on the smasung menu, it may well to set too high, setting to 10 or less 0 is better, set too high and it can cause the shadowing you see..
I would turn of any additional processing on the TV. Picture mode should be Standard
Avatar for Gw9
