Discussion topic: SKY Q keeps dropping wifi signal on Virgin Hub
Message posted on 20 Jun 2025 02:53 AM
SKY Q keeps dropping the Virgin WiFi connection.
Watching the TV last night and must have done it 8 times in 30 mins then just reconnects after maybe 15 seconds.
Sometimes it just stutters then starts again.
I have a 1GB connection and it is stable,
Any ideas?
Message posted on 20 Jun 2025 07:51 AM
Re: SKY Q keeps dropping wifi signal on Virgin Hub
You have a 1Gb connection, not 1GB 😉
Yes this is very common. At best doing a network reset in the Q settings might stabilise it for a while
changing wifi channels can help, The Q wants to use channel 36 on 5GHz to talk to the minis and conflicting with that on your own wifi can cause issues.
ultimately you would get a much better experience with either ethernet or powerline adapters. Or hard-wiring into a wifi mesh node, if you have a mesh, has worked for some including me.
Message posted on
20 Jun 2025
07:35 PM
- last edited:
23 Jun 2025
10:52 AM
by
Nimbob
I have had the issue with my Sky Q box ever since I switched over to EE BB from Sky.
I scoured through various online forums but without much success.
I do think I have now found a stable solution that works.
Caveat - I have an EE SmartHub Wifi Hub
Hopefully this would work with your Virgin BB if your router supports it.
Go to Hub Manager typing this in your web browser https://192.168.1.254
Enter the admin password supplied with the Hub
On the Hub Dashboard screen, select Wireless => Change Settings (on the top of the screen)
You shall now see a screen with Main and Compatible WiFi as toggle options
Select Compatible WiFi, turn it to ON
The Network name should automatically have a -COMP at the end
I kept Security setting as WPA2-Personal
Security Password is upto you, I kept the same password as the Main WiFi
WPS is set to ON
I enabled the 2.4 GHz channel only
Keep the the 5 GHz channel disabled
Click on Save and return to the Dashboard screen
Now go to the Settings => Network Connection => Network Setup on your Sky Q box
Select the Wireless netwok with the -COMP at the end & enter the password
Once connected , you should be good to go.
Note - I did not change any settings on the Sky Q box by enabling the secret menu pressing 001 when on the Settings menu
Message posted on 21 Jun 2025 11:54 AM
Hi,
Thanks for the information. I have reset the hub quite a few times. I have disabled 2.4Ghz on the sky q box and it seems to be stable for the minute.
Message posted on 21 Jun 2025 12:53 PM - last edited: 21 Jun 2025 12:54 PM
Oh really? That's very interesting because the Q isn't supposed to be able to connect to 3rd party routers over 5GHz. Intrigue!
